RAKwireless Powers Loginex’s Real-Time Shipment Tracking by Land, Sky, and Sea
Quick Look: Use Case Summary
Supporting Themes LoRaWAN® and IoT Insight
Industry Logistics and Supply Chain
Sub-Industry Cold Chain Management and Asset Tracking
Deployment Area Global Shipments Across Land, Air, and Sea
IoT Product(s) Used Modular Gateways with LoRa® sub-GHz and 2.4 GHz support, Hybrid IoT Network
Highlights
Loginex partnered with RAKwireless to solve critical visibility gaps in global logistics. By combining LoRaWAN and RAK’s IoT modular gateway technology, they created a smart tracking system capable of monitoring shipments in real time, across land, air, and sea. This resulted in high-frequency data transfer, better cold chain protection, quicker response times, smarter inventory control, and seamless scalability, without major infrastructure overhauls. The project also shows how LoRaWAN shipment tracking can support IoT logistics tracking for critical goods moving across complex global routes.
Company Introduction
Loginex is a growing company in the IoT logistics space, focused on fixing the visibility gaps in global supply chains. Its work reflects the growing need for an IoT shipment tracking system that keeps cargo data visible from origin to destination. In just four years, they established themselves as a leading provider of end-to-end tracking solutions for shipments across land, air, and sea.
Loginex is dedicated to delivering cost-effective solutions and modernizing logistics without making big changes to existing infrastructure. Through its partnership with RAKwireless, Loginex empowered renowned companies to track important shipments like vaccines in real time. This makes the solution especially valuable for cold chain monitoring with IoT, where timing and temperature visibility are critical.
The Problem
When You Can’t See Your Cargo, You Can’t Protect It
  1. Global supply chains are complex, especially when sensitive items like vaccines are involved. These shipments travel across land, air, and sea, through varied climates and border zones. Without IoT temperature monitoring for logistics, teams may not notice temperature changes until the shipment is already at risk.
  2. Real-time visibility is still broken in many logistics networks, and gaps in live updates make it hard to catch disruptions early. The cost of late intervention can mean damaged vaccines, missed inventory, or even risks to patient health. Imagine your vaccine shipment sits on a tarmac in a tropical climate for 45 minutes without refrigeration. If your system doesn’t tell you that in time, you’ve already lost.
  3. Also, when visibility fails, who pays the price: your team, your partners, or the end patient waiting for that shipment?
Logistics teams need to answer these questions:
  • What’s happening inside the shipment (temperature, humidity, movement)?
  • Where is it, across borders? In transit? Or at customs?
That’s the problem Loginex set out to solve.
Location
United States
The Challenge
Turning Real-Time Cargo Tracking Into Action
Smart logistics isn’t just about more data. Knowing the problem is one thing, solving it is another. Loginex didn’t just want to collect more data. They needed IoT logistics tracking that could turn shipment signals into timely decisions by not overhauling their systems or creating new complexity.
Here’s where the true challenge emerged for Loginex:
  1. How do you design a tracking system that works across land, air, and sea without relying on cellular networks or expensive infrastructure?
  2. How do you transmit real-time temperature and movement data, without draining batteries or adding bulky equipment?
  3. How do you scale the systems across global shipments without thousands of devices?
  4. How do you ensure smooth integrations into existing operations without disruption?
The challenge wasn’t just about getting better data. It was about making smarter decisions in real time and building smarter systems that required less to do more.
The Solution
LoRaWAN Shipment Tracking at Scale
Loginex needed more than just another data channel. Here’s how LoRaWAN solved each part of the challenge:
  1. LoRaWAN works across land, air, and sea, even without a mobile network. This makes LoRaWAN shipment tracking a strong fit for global logistics operations.
  2. It sends live data like temperature, movement, etc, using very little power. It also supports LoRaWAN cold chain tracking for shipments that must stay at certain temperatures.
  3. One LoRaWAN gateway supports thousands of devices. This makes asset tracking with LoRaWAN easier to scale across large shipment networks.
  4. It fits smoothly into existing operations and allows adding smart capabilities without disrupting what’s already in place.
LoRaWAN turns real-time data into real-time action at scale by keeping the system simple and using less hardware.
But let’s not forget, something needs to collect that data in the first place.
We need a system that can sense what’s happening inside the shipment in real-time and is small enough to work without adding weight or complexity.
IoT gives shipments the power to speak. This is the foundation of an IoT shipment tracking system that gives logistics teams live insight into cargo condition and movement. By adding small sensors to containers or pallets, companies can track what is happening inside a shipment at any moment. These IoT sensors track:
  1. Temperature and humidity
  2. Shipment location and traceability
  3. Excessive movement
  4. Exposure to light
  5. Inventory status
This real-time data collection helped improve cold chain visibility for Loginex. It also strengthened cold chain monitoring with IoT by giving teams clearer updates on shipment condition. We have seen how IoT tracks real-time data and sends it through LoRaWAN across long distances. However, none of this works without the right technology behind it.
Let’s discuss this next!
The Outcome
RAKwireless helped Loginex build a smarter tracking system with fewer moving parts. Using RAKwireless advanced gateways and modular components, the solution easily adapts to different logistics environments and use cases without the need for multiple gateway types. This is where modular IoT gateways for logistics help reduce complexity while keeping the system flexible.
RAKwireless provided Loginex with a solution that was simple to deploy, customize, and easy to scale. It used fewer beacons and gateways, and the installation was much faster, since there was less equipment to set up. The hybrid design assisted Loginex’s large-scale clients like UPS Healthcare, who manage high volumes of sensitive shipments requiring constant visibility. This hybrid LoRaWAN network deployment helped support wider coverage and stronger shipment visibility.
With this RAKwireless IoT setup, Loginex:
  • Improved inventory control
  • Enhanced signal coverage
  • Protected cold chain performance
  • Kept every shipment traceable from start to finish
The RAKwireless IoT solution also supported high-speed data transfer for critical shipments like vaccines, where you can't compromise on timing and data accuracy.
RAK’s Premier IoT Products
Loginex’s shift to a smarter and more connected tracking system was powered by thoughtful engineering qualities found in the RAKwireless IoT hardware. This ecosystem assisted Loginex to confidently operate in high-stakes logistics. It gave Loginex a stronger base for supply chain IoT monitoring across critical shipment routes.
Let’s take a closer look at the key products that helped make this possible:
  • WisGate Edge Pro Gateway
    A high-performance gateway built to support LoRa sub-GHz, LoRa 2.4 GHz, and Bluetooth. Its modular design makes it easy to adapt to various deployment scenarios and reduces the need for multiple device types. This makes it one of the key modular IoT gateways for logistics environments that need flexible deployment. It also allows for additional RF connectivity modules to be added as needed. It offers strong signal coverage and easy integration into existing workflows.
  • 2.4 GHz LoRa Module
    This module extends the range and bandwidth of the tracking system to make it ideal for data-intensive applications like healthcare logistics. It ensures reliable transmission even in complex environments and across wide delivery routes.
  • LoRaWAN Hybrid Support
    Loginex achieved better flexibility and coverage by combining different LoRa frequencies in one solution. This hybrid setup reduced deployment time and hardware count while accurately tracking across land, air, and sea operations.
What makes these products valuable isn’t just their technical specs; it’s how well they work together to solve real problems.
Success Markers for Loginex’s Logistics
Here is a list of Loginex’s performance metrics that are achieved with RAKwireless’ smart IoT solutions.
Key Success Milestones of Loginex’s Logistics
What Improved? What Did it Mean?
Faster Deployments Less time to go live with tracking systems
Less Hardware Required Lower hardware and setup costs
Smarter Tracking Real-time and detailed insights on each shipment
Cold Chain Integrity Safer vaccine handling and delivery
Scalable Setup Easy to expand across more regions
Custom Flexibility One system, multiple use cases
When Smart Got Simpler with RAK
This use case shows that the right combination of LoRaWAN and reliable IoT hardware can transform logistics operations. RAKwireless didn’t just deliver technology, they also delivered flexibility, performance, and simplicity. RAKwireless proved to be a significant technology partner for Loginex in modernizing supply chains for critical deliveries.
Want to see how RAKwireless can help promote your logistics or tracking systems? Want to make things clearer, simpler, or just smarter? Contact us today and let us build something great together.
Getting Started
Let’s create smarter spaces together!
Reach out to our team, and we’ll help you have your first IoT-powered logistics setup.
