How GreenVale Built a Pest Control Monitoring System with RAKwireless IoT Solutions
| Supporting Themes | LoRaWAN® and Internet of Things (IoT) |
| Industry | Environmental & Safety Management |
| Sub-Industry | Pest Control & Facility Hygiene Monitoring |
| Deployment Area | Vineyards, orchards, crop fields, and large rural farming areas. |
| IoT Stack Used | RAK7289V2 and RAK7268V2 gateways, WisDM Tool, and Jerry traps powered by RAK3172 modules. |
Highlight Summary
- GreenVale needed a more reliable way to manage thousands of connected traps across large farms and remote sites.
- Existing systems created stability and management challenges as the network grew.
- RAKwireless supported the system with RAK7289V2 and RAK7268V2 gateways, WisDM, and RAK3172 modules.
- The gateways provide reliable connectivity across large farms and remote locations.
- WisDM helps teams monitor gateways and manage operations from one place.
- RAK3172 modules support reliable communication inside Jerry 3 traps.
- The new setup helps GreenVale scale remote pest monitoring with better stability and visibility.
Company Profile
GreenVale has changed the way the pest control industry works. The company produces remotely monitored automatic pest traps, supported by software that handles all clerical work related to pest control systems. The traps help catch pests more quickly and make pest control more productive. Their solutions keep food safe and maintain high hygiene standards across farms, factories, and food facilities. This creates an IoT pest monitoring workflow that connects traps, software, and field teams.
One key product is a snap trap placed at customer sites. The trap senses when a pest is caught and sends a signal to an app-controlled software. The software then alerts the teams to remove the pest safely as required by authorities. This process removes the need for toxic bait and keeps food safe and clean.
The same software also manages all the paperwork for pest control and connects these traps to a central dashboard. Remote pest monitoring helps teams check many sites without visiting every trap. The system records:
- Real-time pest activity
- Documents infestations and treatments
- Stores historical data for audits
- Manages invoices automatically
- Plans routine checks
Sensors in each trap detect activity, and the wireless system sends this information to a central dashboard. This allows teams to monitor many traps across different locations without visiting each one. The system relies on strong communication and signals to send data from remote or large areas, which is why reliable IoT connectivity is needed.
The Problem
Pest control is a key requirement of keeping food, farms, and workplaces safe. Yet the old methods create more work than value. When a trap does catch a pest, the problem does not end there. Teams must manually record and report pest activity, which often causes errors or missing information that can impact audits. This clerical work takes attention away from solving real problems. A pest control monitoring system helps reduce missed records and slow manual reporting.
In addition, poison bait is another common traditional pest control practice, but it contaminates food areas and harms the environment. As farms, warehouses, and factories grow larger, conventional pest control methods create too many risks and offer little visibility.
Challenges in Reliable Pest Monitoring
Even with smart traps, companies faced challenges in remote farms and large facilities. Traditional wireless methods could not reliably send data over long distances, and devices often failed in harsh weather or dusty environments.
Teams also had to change batteries frequently, which added cost and effort. False triggers and unclear catch reports made planning and response harder. Companies needed a network that could work anywhere, last longer, and provide accurate information without constant maintenance.
Location
Germany
The Solution
It is difficult for companies to manage pests with traditional methods as they expand into larger and more complex farms and food facilities. Businesses often faced high costs, slow responses, and limited visibility across multiple locations. This is because manual tracking and unsafe practices made operations stressful and less reliable. Companies needed a solution that could improve safety and provide live information on time for better decision-making.
GreenVale created a smart pest control system that solved these challenges. Their connected traps capture reports automatically and reduce errors for teams to act quickly. This IoT trap monitoring setup helps teams respond faster with fewer reporting errors. The system eliminates the need for poison and manual paperwork and provides clear data across all sites.
To ensure this worked at scale, RAKwireless supported GreenVale with reliable long-range IoT connectivity via RAK7289V2 and RAK7268V2 gateways, and RAK3172 modules. This gave GreenVale a LoRaWAN smart pest control setup built for large sites. The IoT network enabled continuous communication from remote locations and made large-scale deployment simple and effective.
LoRaWAN Pest Monitoring for Large-Scale Pest Control
To solve these challenges, GreenVale built the Jerry 3 module using LoRaWAN technology. The module is waterproof and dust-proof and uses a mechanical sensing mechanism to maintain reliable trap performance in challenging environments. It also runs for over 18 months on a single built-in battery, which reduces maintenance. The Tring catch detection system helps distinguish real catches from false triggers, so teams can respond with more confidence.
The Jerry 3 module uses LoRa technology for long-range communication, which supports remote pest monitoring across large areas. The company developed Jerry 3 through extensive testing across Europe and collaboration with partners and customers. It represents the culmination of continuous product iteration and is more reliable, stable, and modular than ever before.
The Jerry 3 module also connects to WiFi, and teams can set it up easily through the GreenVale app. New magnetic sensors and updated firmware make Jerry 3 more stable and simple to use. This means traps report accurately, teams can act faster, and the system works smoothly across large farms and remote locations.
Challenges in Full-Scale Installation
LoRa provided Jerry 3 with long-range communication and low power consumption. However, GreenVale still faced several problems as it expanded operations. Managing thousands of traps across large farms and remote facilities required more than just strong signals. Teams needed reliable connecting nodes and clear processes to handle all devices efficiently.
The key challenges for GreenVale included:
- Deploying and managing thousands of traps across large farms and remote facilities proved difficult for teams.
- Even with LoRa, the signals from all traps needed a central point to collect and send data to the software.
- Traps in remote locations required a stable and consistent connection to prevent data loss.
- On-site staff found setting up devices and keeping track of each trap manually to be slow and complicated.
- Teams needed to see trap activity in real-time across all sites to respond quickly and troubleshoot issues without delays.
Overcoming these challenges required more than just smart traps and long-range signals. GreenVale needed a reliable deployment solution that could connect every trap to a central system and simplify overall management.
How RAKwireless Fills This Gap
As we just discussed, GreenVale needed a solution to manage thousands of traps across large farms and remote sites reliably. IoT for pest control needs stable gateways and simple device management. After deploying nearly 1,000 gateways and 55,000 sensors with another system, they decided to switch to RAKwireless for stronger stability and easier deployment management.
They selected the RAK7289V2 and RAK7268V2 gateways for their dependability and the WisDM tool to efficiently organize all devices. Additionally, the RAK3172 module is integrated into the Jerry 3 module to provide smooth and consistent connectivity.
| Problem GreenVale Faced | RAKwireless Solution | Real-World Impact |
| Teams could not collect data from thousands of traps across large, remote farms. | RAK7289V2 and RAK7268V2 gateways act as central hubs to collect all trap data reliably. | Teams get real-time pest monitoring in one place. No more guesswork or missed information. |
| Managing thousands of devices was complex, and manual tracking caused errors. | The WisDM Tool organizes and monitors all devices from a single interface. | Teams save time, avoid errors, and coordinate smoothly across multiple locations as they scale the business. |
| Traps in remote or harsh locations sometimes failed to send data consistently. | The RAK3172 module, integrated into Jerry 3 traps, ensures strong connectivity. | Traps communicate reliably with the gateway, deliver accurate reports, and enable fast responses over long distances. |
| Teams were unable to act quickly or plan effectively due to delayed or inaccurate data. | All RAK components together provide real-time and consistent data flow. | Teams respond immediately to pest captures, plan maintenance smartly, and maintain food safety standards. |
The Outcome
GreenVale successfully scaled its operations with RAKwireless’ up-to-date gateways and modules. The system supported food safety monitoring across farms, factories, and storage sites. The company greatly benefited from WisDM’s stability and smooth deployment management.
They used RAK’s advanced IoT hardware to replace scattered data and slow reactions with clear insights and fast action. In simple terms, this means farmers can trust their traps, act on time, and protect their crops with peace of mind.
Farming is about patience, observation, and care. This is where smart farming IoT helps teams see problems earlier. Technology like RAKwireless does not replace these values; it amplifies them. The new concept of IoT helps reduce risks and makes farming practices more purposeful. The aim of smart farming is to help farmers see what was hidden before.
~ Knowledge guides the way, and thoughtful use of technology
turns action into lasting outcomes.
Scale Smart, Respond Fast!
Expand your pest control operations with RAKwireless’ advanced IoT solutions.
It is time to manage every farm location effectively with our long-range IoT products.
