LockPoint Technologies and RAKwireless – Building Scalable Retail Locker Systems with LoRaWAN
Scalable Retail Locker Systems with LoRaWAN® and RAKwireless
Quick Look: Use Case Summary
Supporting Themes LoRaWAN and IoT Insight
Industry Retail Security
Sub-Industry Smart Locking and Asset Protection
Deployment Area Electronics Retail Chains and Multi-Store Environments
IoT Product(s) Used RAK7268V2 Gateways, Private LoRaWAN Network, WisDM Device Management Tool
Highlight Summary
  • LockPoint Technologies upgraded its offline retail lockers into a scalable smart retail locker system using LoRaWAN and RAKwireless technology.
  • The system helps retailers secure high-value items such as smartphones and tablets while supporting authorized access, real-time activity tracking, and faster inventory handling.
  • RAK7268V2 gateways and WisDM helped LockPoint Technologies build a private LoRaWAN network for reliable communication across large and complex retail spaces.
  • LoRaWAN allowed the lockers to communicate without relying directly on WiFi or cellular networks, making the setup more practical for multi-store environments.
  • The low-power setup reduced maintenance needs and supported longer battery operation for connected locker devices.
  • WisDM gave LockPoint Technologies a centralized way to monitor and manage connected devices across deployments.
  • The solution improved retail locker real-time monitoring, strengthened LoRaWAN retail security, and made it easier to scale locker deployments for major retail brands.
Company Profile
LockPoint Technologies has built trust in the security industry with over 50 years of experience. They have delivered secure lock products for 20 years. Their products dominate the retail security industry and have a significant market share in giant mobile retail stores like BestBuy, T-Mobile, and KPN.
The locker system secures high-value merchandise like smartphones and tablets. These smart lockers use digital locking mechanisms and respond only to authorized access credentials. They operate as part of a connected store network to:
  • Prevent theft
  • Give staff faster access to inventory
  • Support quick customer pickups
Each locker tracks activity in real time, which helps monitor inventory use and detect security breaches. This enables retail locker real-time monitoring across store environments. As store networks expanded and became more complex, LockPoint Technologies realized they needed a system that could scale easily and still deliver live visibility without directly using WiFi or cellular networks. They had the market’s trust, but to stay ahead, they had to upgrade their systems to meet the current demands of modern retail spaces. The system evolved into a private LoRaWAN network retail setup.
Problem Statement
LockPoint Technologies operates in retail security and offers reliable locker systems that help retailers protect high-value items. These lockers functioned primarily as offline units that relied on local access and basic controls.
However, as retail environments evolved with time, these systems started falling short. Retailers needed smarter, connected solutions that could offer more than just physical security. They wanted lockers that supported digital access, real-time monitoring, and centralized control across store locations. This also required a reliable LoRaWAN access control system.
Upgrading to a more advanced system brought new challenges. LockPoint Technologies needed to make sure the new solution could:
  • Maintain stable communication across larger and complex retail stores
  • Use low power to avoid frequent battery replacements
  • Work independently without relying on Wi-Fi or cellular networks
  • Stay simple and compatible with existing store setups
LockPoint Technologies had to meet these needs to scale their locker system. They wanted to keep the setup simple and avoid extra maintenance work.
Location
United States
How LoRaWAN Powers Smart Retail Locker Systems?
A LoRaWAN-based locker system connects smart lockers with low-power wireless communication. It allows retailers to monitor locker activity in real time, control access remotely, and manage operations across multiple store locations from one place.
This approach suits retail environments where systems need to work across large spaces without WiFi or cellular networks. LoRaWAN provides long-range communication while using very little power, which makes it reliable for devices that run on batteries and need to operate continuously.
The Solution
LockPoint Technologies chose LoRaWAN as the wireless network solution for their new locker systems. It was the right fit as it provided long-range coverage and used very little power to transfer information. It allowed lockers to communicate across wide areas inside retail stores and didn’t require any Wi-Fi or cellular signals. This made it a strong match as a low-power retail IoT solution.
To implement the solution, LockPoint Technologies partnered with RAKwireless as its LoRaWAN hardware and integration provider. RAK’s technology enabled LockPoint Technologies to build a secure private network with easy-to-deploy operations.
The smart retail locker system became more autonomous and flexible than ever. This, in turn, reduced compatibility concerns and allowed retailers to install it quickly with less support and IoT infrastructure. The setup enabled a secure private LoRaWAN network retail deployment and works through a simple flow where each component plays a specific role in the overall system.
How Does the System Work?
This system follows a simple structure where each component works together to enable communication and control across the locker network. Each part has a clear role, which helps keep the system reliable and easy to manage.
The table below shows how the main components interact within the setup.
Component Role
Smart lockers Send status and access data
LoRaWAN network Enables long-range communication
RAK7268V2 gateway Collects and forwards data
WisDM platform Manages monitoring and control
These components together create a connected system that enables secure communication, real-time monitoring, and centralized control across retail locations.
Why RAKwireless?
The Main IoT Tools Behind the Network
With LoRaWAN as the chosen network protocol, LockPoint Technologies used RAKwireless IoT infrastructure that brought the system to scale.
LockPoint Technologies partnered with RAKwireless for three key reasons.
  1. RAK7268V2 Gateway and WisDM Management Tool
    Firstly, RAKwireless offered a complete set of products that allowed them to build a private LoRaWAN network. This included the RAK7268V2 LoRaWAN gateway and WisDM IoT device management tool. These tools made it easy for LockPoint Technologies to launch and control its systems.
  2. Upgraded Security
    RAKwireless provided advanced security features. This gave LockPoint Technologies the confidence to roll out the solution to large-scale clients like KPN and T-Mobile.
  3. Affordability
    Lastly, the solution was cost-effective. It required less hardware and reduced operating costs. That made it easier for LockPoint Technologies to expand into more retail stores without increasing complexity or budget.
Together, RAKwireless and LoRaWAN gave LockPoint Technologies the foundation for launching a smarter and more scalable solution. This solution is designed to solve specific challenges that are common in modern retail environments.
When to Use this Solution?
This solution works best in retail environments where communication and control need to stay reliable at scale. Use this solution when:
  • WiFi coverage is unreliable
  • Devices need a long battery life
  • Deployment spans multiple retail locations
  • Centralized monitoring and control are required
These conditions make LoRaWAN a practical choice for building scalable and easy-to-manage smart retail locker systems.
Outcome
With RAKwireless tools in place, LockPoint Technologies transformed its locker systems into secure and efficient platforms. Their clients gained real-time visibility and tighter control over their products. The retailers could now offer a seamless shopping experience, knowing that their high-value products were safe and accessible. This also improved retail locker real-time monitoring and access visibility.
The lockers ran on a stable network, demanded little maintenance, and enabled fast communication across retail stores. By integrating the latest RAKwireless IoT technology, LockPoint Technologies made its systems easier to expand. This improved customer convenience for them and strengthened security for store operators. The system supports efficient multi-store IoT locker deployment.
RAKwireless did not just supply IoT products. It helped LockPoint Technologies build a system that is ready for the future and now powers some of the world’s leading retail brands.
Getting Started
Ready to upgrade your retail security with smarter locker systems?
Reach out to our team, and we’ll help you plan your first LoRaWAN-powered locker solution.
