Ecothrive Optimizing Precision Agriculture with the Latest RAKwireless IoT
Quick Look: Use Case Summary
Industry Smart Agriculture
Sub-Industry Precision Crop Monitoring
Deployment Area Outdoor crop fields and greenhouses
IoT Stack Used RAK7267 gateway devices, RAK11720 wireless modules, and Ecothrive’s proprietary plant insight system
Highlight Summary
  • Ecothrive helps farmers monitor crop health in outdoor fields and greenhouses.
  • Farmers needed reliable field data to reduce guesswork and act faster.
  • Manual checks made it harder to track plant health, irrigation needs, and changing field conditions.
  • RAKwireless supported the solution with RAK11720 wireless modules, gateways, antenna design services, and custom enclosures.
  • The setup helped send plant and field data to the cloud more reliably.
  • The result was easier crop monitoring, faster installation, and smarter farming decisions in real field conditions.
Company Profile
Ecothrive is a company that created a plant insight system for farmers to support crop monitoring in practical conditions. The business aims to help fruit and wine businesses, particularly in the face of climate change challenges. It all began as a university project, and soon they turned it into a real business that provides better technology to local farms.
The mission of Ecothrive’s intelligent agriculture system is to create a seamless link between the field and the farmer. It helps farmers understand their crops better and produce high-quality harvest. The new farming solution also saves water, minimizes fertilizer use, shrinks carbon emissions, and also saves on labor expenses.
To bring their system together, Ecothrive needed sensors that were compact and could send data from remote farming areas, while meeting the practical needs of agricultural sensors in outdoor environments. The devices had to install easily, operate reliably over time, and send data directly to the cloud via smart gateways.
Better Farming with Wireless Monitoring
Modern agricultural techniques are progressing every day. Farmers need to replace outdated practices with smarter methods to improve crop yields. This shift is a key part of smart farming, where data helps growers act earlier and more confidently. They need an easy-to-use solution that gives them timely insights before problems spread.
This article discusses how advanced technology provides real-time insights into plant health. It also shows how these tools are gradually replacing conventional farming methods across modern smart agriculture applications.
Farmers can now use small sensors and wireless systems to watch over their fields, reduce waste, improve yield, and crop quality. The key to this transformation is reliable and easy-to-use IoT hardware that installs quickly and keeps working longer, especially in remote areas. This is where agriculture IoT becomes useful for farms that need connected devices without a complex setup.
Problem
Many farmers still depend on guesswork to maintain their crops, and this is causing real damage. Without reliable field data, they often water too much or too little, miss early signs of disease, or apply fertilizers when they are not needed. This becomes even harder when soil moisture sensor data is not available to guide daily decisions. This wastes their resources and directly affects crop quality and income. Manual farming systems can’t react fast enough to changes in weather or soil, and even newer tools in the market become useless if they are too complicated to use.
For Ecothrive, this challenge was directly connected to crop monitoring in fruit and wine farms. Their customers needed compact sensors that could stay attached to plants, collect reliable field data, and keep working in outdoor conditions without constant maintenance. Without a stable way to send plant and field data to the cloud, farmers could not get the timely insights needed to understand crop stress, irrigation needs, and plant health changes.
Location
New Zealand
The Solution
Why Ecothrive Chose RAKwireless
Ecothrive strategically collaborated with RAKwireless for the advanced RAK11720 wireless modules and RAK7267 gateway devices. The compact sensor modules, which embed the RAK11720 wireless module, attach right to the plants and tree trunks. They send field condition data to the cloud through RAKwireless’ latest RAK7267 gateways for easier farm monitoring across fields and greenhouses.
A few other key considerations also influenced Ecothrive's decision to engage with RAKwireless, like:
  • Plant Growth Analysis
    The RAK11720 wireless module transmits real-time data collected by the sensor device and helps build correlations between the plants' seasonal states, specific fruit quality parameters, and yield outcomes.
  • Designed for Longevity
    The sensor devices with embedded RAK11720 wireless modules use very little battery power. They last five to ten years on a plant stem and come with Bluetooth for easy configuration through the app.
  • Customization Options
    RAK7267 gateways easily integrate with Ecothrive’s specific software requirements. OpenVPN extensions for backup access make agricultural applications more adaptable.
  • Installs in Minutes
    RAK7267 gateways significantly reduce setup time from 16 minutes to just 2 minutes. This is crucial in time-sensitive agricultural environments.
  • Optimized for Farm Use
    The RAK7267 gateways run on solar power, which makes them perfect for farms that don’t have easy access to electricity.
The RAKwireless team went on a farm visit to better understand the challenges Ecothrive was facing with growing kiwifruit and discuss compatible design solutions. The team also assessed how the sensors and gateways would perform in real field conditions. Small upgrades like faster setup or solar integration make a real difference, especially when the environment is unpredictable.
Optimizing Farm Decisions
The company is also working on an irrigation device to give farmers a good picture of their fields and have a complete feedback loop. This new system delivers real-time data to help farm owners make more effective financial decisions and protect the environment from cropping practices.
RAKwireless plays a key role beyond just providing IoT hardware. The company also provides antenna design services and makes custom enclosures for Ecothrive for a complete and well-rounded precision farming solution.
Ecothrive’s success shows how smart technology can change farming for the better. By working with RAKwireless, they created tools that help farmers solve today’s problems. It started as a simple university project, and the solution now helps farmers around the world. This was a significant advancement in precision agriculture and will eventually make farming more sustainable for the future.
Contact Today!
It is time to be smart and grow better crops with less guesswork.
RAKwireless’ advanced solutions will help you stay connected longer in remote crop fields.
