EcoMeter Powers Sydney’s Smart Metering with RAKwireless Gateways for LoRaWAN®
| Industry | Smart Buildings & Urban Infrastructure |
| Sub-Industry | Utility Monitoring & Management |
| Deployment Area | Large commercial buildings and residential complexes |
| IoT Stack Used | RAK7289V2 outdoor gateways, WisDM, WisGateOS 2, WisGateOS 2 Extension, and LoRaWAN connectivity |
Highlight Summary
- EcoMeter addresses the need for continuous utility monitoring with 24/7 smart metering services.
- The company developed an online platform that provides real-time utility data, alerts, and dashboards in one simple system.
- RAKwireless gateways for LoRaWAN support reliable connectivity across large buildings and urban areas.
- These gateways form a LoRaWAN utility network that supports EcoMeter’s smart metering operations across Sydney.
Company Profile
Sydney is a busy city and is undergoing a technological change. Traditional meter reading methods take time and often give wrong readings, which can waste money and resources. To address these problems, EcoMeter is installing smart meters in Sydney, Australia, to manage utilities effectively.
EcoMeter fills this market gap by providing 24/7 smart metering services. This approach supports LoRaWAN smart metering for buildings that need continuous utility data.
The company has an online platform that uses the latest web technology to give instant and accurate data with smart alarms. Their web system has a simple interface that anyone can use without needing any training. EcoMeter also offers real-time graphs and customizable dashboards to provide people with detailed insights into their utilities. A wide range of users can check their water, electricity, and gas usage at any time once this solution is in place. The platform brings utility monitoring IoT into one simple system for everyday use.
Problem Statement
Many businesses still use the old way of manually checking gas, electricity, and water meters each month. This conventional in-person reading approach comes with a series of problems that build up step by step and eventually strain corporate budgets. Every challenge leads to a larger problem across industries like energy, education, hospitality, and healthcare. The chain of issues looks something like this:
- The monthly meter reading system depends highly on personnel availability.
- The process itself takes time and often causes reading errors.
- It takes longer to accurately detect any abnormal utility usage due to leaks, faults, etc.
- As a result, it becomes difficult to forecast demand and address problems promptly.
- This, in turn, leads to resource wastage and higher costs due to excessive consumption.
- Eventually, budgets and overall cash flows of businesses are disrupted.
These challenges make smart utility monitoring increasingly important for modern businesses. Therefore, businesses nowadays need smarter systems to control costs and monitor their utilities.
It is difficult for companies to keep track of their utilities because traditional methods mostly rely on manual meter checks and delayed billing information. This can lead to waste and higher expenses.
Location
Australia
The Connectivity Challenge
EcoMeter had a smart system ready to track utilities efficiently. However, the city posed several challenges that made collecting accurate data difficult.
Key challenges included:
- The city is large, with tall buildings and crowded areas, which made network coverage tricky.
- Traditional networks would have been expensive to install and slow to operate across all locations.
- Battery-powered meters could run out of energy too quickly under high-demand systems.
- Meters sit on different floors, inside offices, or behind thick walls, which weakens signals and reduces reliability.
- Businesses and residents need accurate readings on time, but old networks could not deliver consistent results.
These challenges meant EcoMeter needed a strong, efficient network that could reach every meter, maintain reliable connections, and provide timely utility data to all users across the city. The network also needed to support reliable connectivity across a smart building LoRaWAN environment.
The Solution
The company has started a project to deploy smart metering solutions for large buildings in the city. They have integrated almost a hundred RAKwireless outdoor gateways for LoRaWAN throughout the city. The RAK gateways are strategically placed atop buildings to cover large areas and allow EcoMeter to oversee utility usage across the region. The aim is to improve the way businesses manage their utilities for a fair idea of how they use water, electricity, and gas each month.
The purpose is to create a city-wide network that facilitates reliable utility monitoring. This forms a scalable LoRaWAN utility network for connected buildings across Sydney. The system supports water, gas, and electricity monitoring across large buildings. This is how the company aims to help buildings prevent waste, reduce costs, and give timely information to both businesses and households.
This can help companies spot unusual usage early, control costs, and plan resources more effectively. Let’s discuss how EcoMeter uses RAKwireless gateways to make utility management easier and more accurate for both businesses and residents.
Going with LoRaWAN Technology
EcoMeter opted for the LoRaWAN network to address these challenges. The key feature of LoRaWAN is that it uses very little power and has long-distance real-time transmission capabilities. This makes it a perfect network solution for smart cities and buildings. These gateways for LoRaWAN provide reliable connectivity for smart buildings across large urban areas.
To implement this, EcoMeter placed RAK7289V2 outdoor gateways on multiple rooftops across Sydney. The gateway network is already in place, while the broader smart metering deployment continues across the city. These gateways create strong coverage and allow the company to collect utility data from many locations at once.
This is because LoRaWAN can perform very well in busy urban environments. The project also shows how smart building LoRaWAN can support connected utility systems. Together, the gateways form a LoRaWAN utility network across Sydney.
The Edge of RAKwireless in IoT Deployments
EcoMeter needed a technology partner that could support city-wide smart metering with reliable IoT hardware. They required gateways that last long, a platform that simplifies management, and tools that comply with local regulations. RAKwireless met these needs with a range of robust products and advanced software solutions.
The WisGate Edge Pro V2 supports reliable gateway operations across the smart metering network. The primary factors that led to this strategic collaboration are:
Optimal Coverage and Connectivity
The placement of gateways supports optimal coverage across Sydney. This helps prevent signal interruptions and enables consistent data transmission from utility meters. -
Solid and Reliable Gateways
RAKwireless gateways are durable and built to last. Their strong build helps keep the network active even in harsh weather and busy city conditions, where many other devices fail. -
Ease of Use
WisgateOS 2 provides a consistent interface across different hardware devices. This makes it simple to configure gateways at any location without confusion or any training. -
Remote Management with WisDM
EcoMeter uses WisDM to manage gateways from remote environments. WisDM gateway management also simplifies fleet-wide configuration and monitoring. Recent improvements made the platform easier to use and more reliable, with key features like:
• Simple interface and clear processes that help the team efficiently manage gateway fleets.
• Ongoing updates and fixes that improve WisDM’s reliability and functionality for everyday use.
• Moving gateways between locations, bulk syncing settings, and location-based grouping list filtering that further improve operations. -
Compliance with Regulations through WisGateOS 2 Extension
WisGateOS 2 Extension supports WireGuard and helps EcoMeter meet local government rules that restrict servers outside China. With this feature, users can manage gateways securely without altering the firmware. It gives companies control and peace of mind while staying fully compliant with the regulations.
RAKwireless provides more than just hardware. Our combination of reliable devices, easy-to-use software, and regulatory support gives EcoMeter the confidence to run city-wide smart metering in a secure manner.
Results
EcoMeter has integrated almost a hundred RAKwireless outdoor gateways for LoRaWAN across Sydney as part of its smart metering project. The gateways are placed on multiple rooftops and form a LoRaWAN utility network for connected buildings across the city. EcoMeter also uses WisDM to manage its gateway fleet remotely.
EcoMeter sees great value in new features that make their work faster and easier. They want the option to move gateways to new locations when needed. They also want to apply the same settings to multiple gateways at once instead of configuring each one individually. Another goal is to sort and group gateways by their location so teams can find and manage them more efficiently.
Looking ahead, EcoMeter hopes RAKwireless will provide pre-configured gateways. Currently, every gateway needs a skilled technician to configure it before it can go into service. This process takes time and adds extra cost. If RAKwireless supplies ready-to-use gateways, EcoMeter can deploy them faster, save money, and start collecting utility data without any delay.
EcoMeter’s collaboration with RAKwireless showcases a successful integration of IoT solutions in smart metering. By using LoRaWAN and RAKwireless gateways, they have built a system that is reliable and able to handle the challenges of urban environments. The company continues to look for ways to streamline its operations and make its services stronger.
Contact Now and Take Control of Your Utilities Today!
Discover the IoT potential in smart metering with RAKwireless.
It is time to give your building real-time insights and accurate tracking of utilities.
